ok i see all these people talkin about how they wire their stuff at .5 ohms. how does that work? i mean like on amps, the ohms are usually 4, 2, n 1. well im askin this because right now i got 1 dvc ssd 12" (bp n flatwound) with a hifonics amp powering 1200rms watts at 1ohm. i was thinking of getting another ssd, so that mean i would get an amp to power 2400rms watts. i looked at some of the wiring configurations on kicker n 12voltz website n it shows that i can only have them at 2 ohms or .5 ohms. at 2 ohms the amp i wanna get is kinda really outta the way money wise because at 1ohm it is a lot more than wat i need. so yea im just wondering how i could achieve the .5 ohm with the set-up of 2 ssds if an amp has 4,2, or 1 ohm rating.
You can't, if the amp is only stable down to 1 ohm safely...
then wat do you recommend i get?
yeah no chit.. runnin .5 ohms is not nice for your amp nor is it safe, or recomended, but it is very cool, and fun, and boss like....... not boss like boss amps boss like tony soprano boss like
wait what? i dont understand what your sayin?
A pair of Sundown 1500d amps strapped at 2 ohms should do the trick.
how would i wire the amps together? i know how to wire the subs to get a 2 ohm load only...
