is there any specific way of wiring a Fi Q into 1 ohm? Its the dual 2 ohm. Do I wire to one speaker terminal or both? wiring diagram will help.
OK theres 2 ways to do this you could wire your + to your + and - to your - on the speaker then go out to the amp. or you could take each terminal off the speaker to its respective terminal on the amp. Personaly Id rather go with the first option
