Posted January 30, 200818 yr I have a mazda ext cab pickup and have about 12cu feet to work with. I really want the FI Q18's. I have never owned a pair of 18's and that's what i want. I want to kind of do what Steve Meade did in his honda and build the enclosure inside of the truck. If i can't do that this is the space i have to work with 30in high x 49in wide x 14in deep. If i built inside i think it would be a little bigger. I was wondering if I can't fit 2 of the Q's, should I just use 1 of the Bl's?
January 31, 200818 yr you may be able to do two 18" Qs sealed but you'd probably be better off with a pair of 15s or 1 18 (ported)
January 31, 200818 yr Author I have 2 mtx ta7801 amps. I'll be getting 4 of the audioforce 1100's and i will be having Iraggi Alternator get me a 200amp alternator for my truck. Edited January 31, 200818 yr by Jayson
