Posted February 22, 200818 yr Im intrested in purchasing 4 15" BL subs. I want to know what options i need to include to make this a low maintenance daily setup in my tahoe if I am using 2 orion 2500d's. I have dual alts and proper charging taken care of. Just need help with the recipe for the Fi's.
February 22, 200818 yr Admin If you are running a pair of 2500D's, I would suggest a secondary battery or two, in addition to a few runs of 1/0 or 2/0 wire to get the most current to them.
February 22, 200818 yr Author If you are running a pair of 2500D's, I would suggest a secondary battery or two, in addition to a few runs of 1/0 or 2/0 wire to get the most current to them.I have 3 2400 kinetik's and 1 1400 kinetik. 2 1/0 runs. I need to know what options i should get on the subs.
February 22, 200818 yr Admin Ok, I did not understand that by your original post. If you are going to lay into them on a daily basis, I would suggest the cooling and maybe P chamfer.
February 23, 200818 yr Thats about 1200 rms a piece which they should handle fine stock but you could get cooling on them or something..... Wouldn't put every option on it cause it would be a waste of money unless your pushing about 2000 rms to each....
February 23, 200818 yr Im intrested in purchasing 4 15" BL subs. I want to know what options i need to include to make this a low maintenance daily setup in my tahoe if I am using 2 orion 2500d's. I have dual alts and proper charging taken care of. Just need help with the recipe for the Fi's.Stock ones will work fine for youThanks!-Nick
