ive got a 1500d on 4 12's.i just turned my gain up a tad bit and now its hittn hard but skippn my cd player when it hits a certain bass note.ive got to fix this probablem cause i do competitions and i cant be having that.ive got a alpine 9885.any sugestions as to what i can do.thanks guys.ive still got another amp to put in.thats why im worried
you gotta get that cd player secured.
IF it's screwed\bolted down properly then put some rubber washers around the mounting holes to see if that helps.
Does the cd player rest on anything other than the screws\bolts that hold it in?
You can line your CD cavity with closed cell foam. You should also consider Second Skin to deaden your entire car. This will ultimately help the problem.
the bolts r the only thing holding them n place.should i put a piece of clothe inside to secure it or what.thanks man
use the Ipod cable and an Ipod then it shouldn't skip. Z
changer is the way to go.i had to get one for my crx after about 150ish and when i played some street bass in it
If I may ask why, in your opinion, would a changer be better?
i was gonna do the changer.hope it works.what kind of ipod could i use w my alpine 9885?thanks guys for the help
Do you have one yet? do you have the Ipod cable as well yet?
i dont have a cd changer yet or a ipod cable.just wantn to know what would be best.thanks for all the help guys
my changer has yet to skip even playing @ mid 50's at 54 hrtz or playing any song i can get my hand's on with 2 9515's tuned to 35 hrtz with 2 3000's.
good,ill go with the changer and hopefully that will help alot.thanks everybody.sundown all the way!!!!!!!!
one more thing in usaci and dbdrag you can not use a ipod.not saying some people wont let you use it but it is in the rule's
