Posted March 24, 200817 yr Sub broken in for about 60 seconds at high excursion then specs tested:Fs = 38 HzRe = 2.92 ohms (series)Qes = 0.466Qms = 8.64Qts = 0.44Le = 3.05 mHVas = 36.67 LCms = 49 uM/NMms = 339 gramsBL = 22.84 N/A
March 24, 200817 yr Author Was this the dual 1ohm or 2ohm?D2.I'll get D1 specs later on today, I've been testing all the shipping subs today so I went ahead and measured TS on a D2 before I packed it up.
March 24, 200817 yr Author Specs won't make it up today for the other coil configs -- but I'll get them all ready tomorrow Also... keep in mind this is a 60-second break-in. The Fs will drop some more as time goes on, expect a few Hz lower after a month or so. These spiders are very consistent after the initial 60-second break-in so they won't change a whole lot, but you will get a few Hz drop in a few weeks of play.
March 25, 200817 yr Author We put one of these 15s in my friends Bronco last night and drove around with it for a few hours and barely got it warmed up with the SAE-1500D proto on tap. And before anyone asks... no pics or ETA on that model amp yet.
March 25, 200817 yr Author Any other sizes? 12" or 18" perhaps?Yep, 12" are in stock as well in D1 and D2 coils.No 18s or 10s yet.
March 25, 200817 yr My L shaped horn broke my MD / FI Napalm Hyrbid so I am hoping to swap it out with a Nightshade...Specs are looking tasty...
March 25, 200817 yr Author My L shaped horn broke my MD / FI Napalm Hyrbid so I am hoping to swap it out with a Nightshade...Specs are looking tasty... T/S for the 12" model are posted on here too if you search around a bit
March 25, 200817 yr My L shaped horn broke my MD / FI Napalm Hyrbid so I am hoping to swap it out with a Nightshade...Specs are looking tasty... T/S for the 12" model are posted on here too if you search around a bit No 12"s...I need a big hefty 15"..Whats the depth on it?
March 25, 200817 yr Author My L shaped horn broke my MD / FI Napalm Hyrbid so I am hoping to swap it out with a Nightshade...Specs are looking tasty... T/S for the 12" model are posted on here too if you search around a bit No 12"s...I need a big hefty 15"..Whats the depth on it?Alot *laughs*9.75"
March 26, 200817 yr Author The D1 specs are essentially the same within a few %, with the only real difference being this:RE: 1.44 ohmsBL: 16.68 N/ALE: 1.35 mHCoils in series.
March 26, 200817 yr gonna have to look in to getting a few of these lookin nice waiting to see what ppl say about them as far as daily use
