Posted March 29, 200818 yr Ive got 2 BTL 15s and i wanted to make sure my calculations were correct before i started building. The total room i have to work with is h=23 w=24 l=39inches. Total internal volume is 10.5 cubes, and after all displacements i have 8.65 cubes. the port dimensions are h=22.5 w=4.5 l=18.4 which should make the box tuned to 33hz. can someone check this for me to make sure i didnt make any errors.Thanks Keith
March 29, 200818 yr hey i was wanting to build a box for a 12" SSD and i wanna ask you how do you know that those dimensions will have the box tuned to 33hz? thanks... n sorry i couldnt help...
March 30, 200818 yr Author Theres a formula but its kind of confusing. I went to carstereo.com, they've got port lenght calculator. Just plug in numbers and it will tell you how long your port should be for the tuning you want. I dont know if its accurate, thats why im tryin to get some help from the pros.
