March 30, 200817 yr Author If that includes electrical you are going to need more money.electrical is takin care of..
March 30, 200817 yr are they d1 or d2 and how much power you looking to put to them...................
March 30, 200817 yr Author are they d1 or d2 and how much power you looking to put to them...................dual 1s..daily system so 2k a piece would be nice...its in a jeep..
March 30, 200817 yr JoshHD6 - you in the same city i'm in, gotta hear it when you get it all setup.refurb saz-3000d2 opti2000ds strapped @1ohm4 refurb opti1400dsyou can get all that for under $800
March 31, 200817 yr Author JoshHD6 - you in the same city i'm in, gotta hear it when you get it all setup.refurb saz-3000d2 opti2000ds strapped @1ohm4 refurb opti1400dsyou can get all that for under $800where are u located in louisville? everything will be in by the end of april..
March 31, 200817 yr personaly I would go whith the saz-3000d (refurb)for around $800..............can the jeeps elec. system handle it thow..........the 3000d is very eff. but the better the elec. backbone is the happier you will be in the long run
March 31, 200817 yr these are a little underrated, and on sale since the new line is coming out... awesome amps and a great buy!http://www.woofersetc.com/index.cfm?fuseac...Product_ID=3195for something new I would do that, if not then do either one sundown 3000d refurb, or two 1500d's strapped.
March 31, 200817 yr You could spend $100 more and get 2 Crunch GP3000D if you are looking for a budget.You can strap them together for around 6kwrmshttp://www.onlinecarstereo.com/CarAudio/Pr...ProductID=18538
March 31, 200817 yr http://www.stevemeadedesigns.com/board/ind...15609&st=40Power accoustic 5500s. one on each amp at 2ohms would be good.You could find a memphis 4k, RF T4000, or several others used for that price, or around 1000 new if you search. The termpro forum is down right now, but they have AB 500.1s pretty often. A little more than you're budget but you can find used ones pretty often.http://cgi.ebay.com/Hifonics-Goliath-5000w...1QQcmdZViewItemGood luck
April 1, 200817 yr Author http://www.*****.com/board/ind...15609&st=40Power accoustic 5500s. one on each amp at 2ohms would be good.You could find a memphis 4k, RF T4000, or several others used for that price, or around 1000 new if you search. The termpro forum is down right now, but they have AB 500.1s pretty often. A little more than you're budget but you can find used ones pretty often.http://cgi.ebay.com/Hifonics-Goliath-5000w...1QQcmdZViewItemGood luckthanx for the help guys..ill probably go with the sundown..heard it will do close to 4kw with good eletrical..plus my 200 amp alt will be here soon..and shizzon where are u located in louisville?
April 2, 200817 yr well i do believe that is your best bet but the saz-1500's did peak more at higher voltage i believe
April 2, 200817 yr well i do believe that is your best bet but the saz-1500's did peak more at higher voltage i believeThey do slightly but in this case at 1 ohm nominal load before impedance rise a pair of saz-1500d's would be strapped and running .5 ohm nominal impedances each voiding the warranty for a couple hundred watts.
