Posted March 30, 200818 yr Ok so in the manual it loooks like I have to connect both positive speaker out terminals to the + speaker and both negative to the speaker negative to run it bridge... is that correct?On my other amps it was always the positive to speaker A + and the negative to speaker B negative
March 30, 200818 yr You aren't bridging the amp at all, it has only one channel.It has two sets of terminals for wiring convenience and strapping. You can use just one set of + / - if you like.
March 30, 200818 yr Author You aren't bridging the amp at all, it has only one channel.It has two sets of terminals for wiring convenience and strapping. You can use just one set of + / - if you like.Ok thats great to know!So I can just connect both to terminal A and be fine... I forgot that it is single channel LoL Im use to dual channel I guess...
