Posted March 31, 200818 yr Ok, so I was wondering. A 12 in it's largest recommended enclosure, or a 15 in its smallest recommended enclosure, which has the more potential to get louder? Playing around with ideas here.Thanks,~Trevor
March 31, 200818 yr What kind of sub what are your plans, Do you like loud,low?Please tell moreI prefer a larger sub as cone area is hard to beat
March 31, 200818 yr In a sealed or ported box? How much power? Which Sub? What altitude? What electrical system? How many volts on your HU? What car? What kind of wood will the box be built with? Will you fiberglass the inside? Carpet the outside? What temperature will the air be? Will the amp be ran in a cool environment.Until you can answer all of those questions and MORE, there is no way to tell you which will be better. It really comes down to what you can FIT.
April 3, 200818 yr Author In a sealed or ported box? How much power? Which Sub? What altitude? What electrical system? How many volts on your HU? What car? What kind of wood will the box be built with? Will you fiberglass the inside? Carpet the outside? What temperature will the air be? Will the amp be ran in a cool environment.Until you can answer all of those questions and MORE, there is no way to tell you which will be better. It really comes down to what you can FIT.Heh, wasn't thinking. But I'm almost positive I'm gonna go with a BL on 1500D. I love my rap music, which hits pretty low. Ported box for sure. Altitude... probably SL to 250ft ASL. I can probably fit the BL15 in a smallerish box, or the biggest BL12 box. I'. guessing the largest box for the 12 would work better.Thanks again,Trevor
