The final specs will look like this:
Re = 3.37 ohms (4 ohm nominal)
Fs = 34.9 hz
Qes = 0.5323
Qms = 6.93
Qts = 0.4943
Vas = 7.6 L
BL = 13.3 N/A
Mms = 127.7 grams
Cms = 162 um/N
Xmax = 12mm one-way linear (70% BL method)
Rated RMS Power = 200 watts
Depth = 4.25"
OD w/ gasket = 8 5/16"
Cut Out = 7"
Sealed Box:
0.280 ft^3 w/ F3 of 50 Hz (Qtc = 0.707)
Ported Box:
0.60 ft^3 tuned to 30 Hz
F3 of 25 Hz
So... anyone who wants to pre-order these can do so whenever they feel like it. I will continue to run the intro sale for a few weeks after they come in, so no hurry - but if the money is burning a hole in your pocket - order away!
Paypal $65 each to [email protected] for one driver.
If you want FOUR of them then send over $240 and they are yours (60 each).
If you want EIGHT of them then send over $440 and they are yours (55 each).
Prices are shipped in the continental USA.
Production models will have black basket and motor.
  • Replies 123
  • Views 17k
congrats on the new line, was wondering what the rms is on these?
Rated for 200 watts RMS.
Sean has had the original prototype for quite a while on a 400-watt amp - using common sense one can use a larger amp on them, but don't get carried away. We also "burp" tested one with 800 watts and got a bit over 143 dB in his CRX (legal at the windshield, windows up) in a 4th order bandpass.
this maybe my replacement for my kicker 8 in my wrecker....
How does that hiy 143dB when I have 2 12" BMs nd hit 143.6 only?!?!
all in the box/ install.
True, mine is the recommended size and porting for the BMs, its a SQ box, not optimized for SPL at all.
and sean has had that crx for years and knows how to get loud in it.......
iirc he has done over a 150 with 2 xcite 8's
think i'm gonna have to grab 2 for my frontier..no bass is getting old
now if sean will just share the specs on that bandpass....
Do they play nice in IB? just curious.
Yup, they should work fine IB.
So any spl results yet from something other than a fart box like recommended sealed/vented?
I'm really thinking about picking up 4, but don't know if I want to use them in my Magnum or as the sub section in my semi-active towers i'm planning.
I'll have to talk to Sean and see what it's doing in his daily box, although, I believe he ran the "fart box" daily and it worked nicely.
i think i'mma use my stimulative check for this :) weeeeeeeeeh
Yang
I'm pretty excited about them... will be making a box for four of them for my VW.
I think 4 of these and a SAZ1500....will make my day.....I will get 4 of them and port them!
hey bro i'am new here so don't get upset if i might ask a stupid question, i want to know the price of two of these. 8" thanks
Brent,
If you check the first post in the thread you will see pricing listed as follows:
"Paypal $65 each to [email protected] for one driver.
Prices are shipped in the continental USA."
They are on pre-order until the end of May, when they are scheduled to arrive.
I think I might want to get sixteen.
Not sure if I can port if I do that, probably have to go sealed.
Or should I just do 8, with a large port?
This a trunk car, and if I tried to port with 16 drivers, the port couldn't really fit in the cabin.
16 sealed >= 8 w/ large port?
I dunno, I'm hung up on it, I was also considering 2 15's btl's. :shrug:
I have 1 3000D atm, with a 200 amp alt, and 3 group 31d's, with a 1600 kinetik under the hood.
Going for loudness at low frequencies. Considering another 3000D
I just wanna make sure, that these coils are single, 4 ohm coils? I dont want to kill the amp, but I was doing some numbers with what the ohm load the amp will see.
if I get 16 speakers, I can wire them to 1 ohm, or .25 ohms., or 4 ohms......so two sets of 8, I can get .5 ohms each, or 2 ohms each......... basically I'm looking at 8000 watts/'500 each 1 ohm strapped, 3200/ 200 each @ 4 ohm strapped....or kill 1 amp @ .25 ohms and get maybe 5000? with 312.5 per speaker.
with 8 speakers, I can do 4000 w/ 250 per speaker 1 amp. @ .5 ohms....2 amps, 6000 watts @ 2 ohms strapped. with 375 per speaker
However I doubt I will get that amount of wattage, but you never know...what should I do, and how much per speaker, @16?...55 each?
also, should I be trying to use that at 4 ohm nom, or should I use the RE.
Edited by Rawr-dq
