  • Replies 123
  • Views 17.4k
Getting quite a bit of interest in these... maybe I should have brought in 500 after all *laughs*
Excuse my ignorance, but are these 8's, 10's or avail in different sizes?
These are 8s only right now.
I have a 12" model that will be next, followed by a 10" model in the "E" line.
How much volume will each subwoofer displace? Gracias!
A very tiny amount, you can pretty well ignore it for calculations... if you want to figure it in it's less than 0.1 ft^3
They are in Charlotte - just waiting on them to clear and make their way here.
If I were to use four of these in a sealed enclosure, what frequencies should I send the subs?
Would there be any reason to send them frequencies above 200 Hz?
As a subwoofer you generally do not want anything over 80 Hz coming from them, so no, there is no reason to cross them above 200 Hz when used as subwoofers.
how would 1 sub sound in an infante baffle. basically on the back dash hanging into my girlfriends trunk replacing oem?
Should sound pretty good - won't need much power IB either.
speaking of power....
In a sealed enclosure, would a kicker 750.1 be too much for two of these subs as a daily driver? The amp is rated at 750x1 @ 2 ohms....
Not really - it depends on the size of the box as the only real limit you'll hit is mechanical. If you hear a funny sound back down the gain a bit :)
Charlotte, North Carolina?
Are you located in NC?
ya Jacob is in NC
have you tested these as a HT sub?
Nope, I have not - should work just fine though.
I cant wait for these bad boys to ship out, jacob you as excited as I am?
You better believe I am!
I want to use these myself :)
Jacob now dont forget i get 64 of these suckers
Oh, I have not forgotten! You are gonna nearly wipe me out of these puppies :)
Once you pick yours up I'm going to start the second production run.
