Posted May 4, 200817 yr 3 12" icons in a sealed 4.5 cube sealed box 3000 watts anyone have feedback. an idea ive been thinkin it may be my new setup
May 4, 200817 yr Author should sound fantastic. what do you have up front? phnx gold rsd 6.5 comps and rsd coax in rear doors. got the doors deaden and will doo entire vehicle when i change. 150w x 4 amp
May 4, 200817 yr Author i posted this in other section want some feedback from the ssa pros, want to do 3 12" icons with 4.5 cubes sealed ,running 3000wts any ideas? i have about 6.5 cubes total i can use maybe 4 12's or 3 15". anyone got ideas on this or other combos? want to try something diff. a clean hard hittin sealed set up
May 5, 200817 yr Admin As long as you can give the 12's about 1.0-1.25 each to start with you will be good to go. So if you have 4.5 for 3 - 12's that is great!
