Posted May 5, 200818 yr what type of set up would you recommend getting for my car to go with a 12 btl? starting from scratch, what would i need done to my car? i have a 2007 mazda 6 hatchback
May 5, 200818 yr Personally, I would probably try starting out with one of their other lines, say a Q with the BP power option or a BL, before stepping right up to a BTL...I wouldn't try running 3kW right out of the gate without some experience first, that kind of current can really ruin your day if you're not careful, but that's just me
May 5, 200818 yr Author Personally, I would probably try starting out with one of their other lines, say a Q with the BP power option or a BL, before stepping right up to a BTL...I wouldn't try running 3kW right out of the gate without some experience first, that kind of current can really ruin your day if you're not careful, but that's just me im not trying to buy a bunch of subs. i want one good sub thats loud as chit now. ill be careful with it lol
May 5, 200818 yr Personally, I would probably try starting out with one of their other lines, say a Q with the BP power option or a BL, before stepping right up to a BTL...I wouldn't try running 3kW right out of the gate without some experience first, that kind of current can really ruin your day if you're not careful, but that's just me im not trying to buy a bunch of subs. i want one good sub thats loud as chit now. ill be careful with it lolTo run a BTL, I would start with:Sundown SAZ-3000whole lotta 0/1 ga wiring2nd battery & upgraded main battery (kinetiks, optimas, powermasters, etc.)Again this is a starting point, as I have no knowledge of what size alternator, head unit, signal processors you currently have.
May 5, 200818 yr Author Personally, I would probably try starting out with one of their other lines, say a Q with the BP power option or a BL, before stepping right up to a BTL...I wouldn't try running 3kW right out of the gate without some experience first, that kind of current can really ruin your day if you're not careful, but that's just me im not trying to buy a bunch of subs. i want one good sub thats loud as chit now. ill be careful with it lolTo run a BTL, I would start with:Sundown SAZ-3000whole lotta 0/1 ga wiring2nd battery & upgraded main battery (kinetiks, optimas, powermasters, etc.)Again this is a starting point, as I have no knowledge of what size alternator, head unit, signal processors you currently have.everything in my car is stock
May 6, 200818 yr I would definately recomend upgrading your alternator/battery/"BIg 3"/ Multiple batteries in the rear.. and lots of 1/0 awg wire
May 6, 200818 yr Author I would definately recomend upgrading your alternator/battery/"BIg 3"/ Multiple batteries in the rear.. and lots of 1/0 awg wire what if i just got the fi q? i have a w6 12 already,but i want something louder but dont wanna spend a ton getting all that new chit. it doesnt mean that much to me, but i definately want it louder
May 6, 200817 yr I would definately recomend upgrading your alternator/battery/"BIg 3"/ Multiple batteries in the rear.. and lots of 1/0 awg wire what if i just got the fi q? i have a w6 12 already,but i want something louder but dont wanna spend a ton getting all that new chit. it doesnt mean that much to me, but i definately want it louderWell no matter what you go with you should still upgrade your "Big 3" and get a better starting battery under the hood... Voltage drops will hurt you and your system so why not spend the extra cash$$ and be on the safe side so you only need to upgrade your vital electrical parts once
May 6, 200817 yr Well no matter what you go with you should still upgrade your "Big 3" and get a better starting battery under the hood... Voltage drops will hurt you and your system so why not spend the extra cash$$ and be on the safe side so you only need to upgrade your vital electrical parts onceExactly. You will not be real happy when you fry your equipment. Take the advice and do things the right way, if not it is a lot of wasted money.
