Posted May 12, 200818 yr I am going to build a test box or two before I build the permanent one.... being a personal project material costs don't matterthis one is going to be SWEET
May 13, 200818 yr Admin I cannot wait to see what you come up with.edit: wonder what the RF crew will think of them when they see the pictures and results.
May 13, 200818 yr Author I cannot wait to see what you come up with.edit: wonder what the RF crew will think of them when they see the pictures and results. last time I looked RF did not make an SQ woofer....but I still have the RF product line and I still have an open invitation to RTTI(Rockford Technical Training Institute) I was modeling the 10" Icon on Termpak last night....WOW do these things likethe low stuff
May 23, 200818 yr Author any updates? I have to build my SPL box for the upcoming comp firstthen I'll be working on the Daily Driver enclosure with 4 Iconsin it
August 14, 200818 yr Author well I found some time to build myself an enclosure for this pairof Icon 10" that have been sitting here doing nothingthis first enclosure is for just two Icons
August 14, 200818 yr well I found some time to build myself an enclosure for this pairof Icon 10" that have been sitting here doing nothingthis first enclosure is for just two IconsThat would be considered a T-Line correct?
August 15, 200818 yr Author it is a re hash of a night club woofer cabinet design I used to make back in the day I would call it some what of a compression Horn....
August 15, 200818 yr Author the enclosure design works well in a car the down side is that a Horn takes up ALOT of spacethese 10" Icons really slam out the low stuff..they are also really tightvery stiff subs....I'll need a couple of weeks to break them in but so farso good
August 16, 200818 yr Author wow~! Sick box. Cant wait to see what you think of these. they are a very good sounding woofer..they handle TONS of powerI'm running over 1200w rms per sub and no fatigue from getting to hot..theystill sound clean and tight even after a good hour + of full tilt I'm digging the low end detail of these subs..very nice I think they have a little more output than my JBL W10gti subs and they definately move more air
August 17, 200818 yr i designed an enclosure like that for an 8 but the sub was firing at what would be your back wall so deeper in the port. i figuired it to be like a ported enclosure firing toward the liscence plate in a trunk car.the back had more room in it than the port itself and worked around intoa horn like yours. id love to know how that box works and what it is tuned to. i was going to try it in an spl setup.
August 17, 200818 yr Author I built this one 2.0cf3 and 35hz tuning and I'll be building another Identical enclosure tuned at 30hz next.... will most likely have a small stock pile of 10" Icon enclosures to sell cheep as is during my experimentation in finding the capabilities of these subs
August 19, 200817 yr i could maybe use one of those 10" enclosures lolbut thats down the road looks great man!
August 20, 200817 yr Author took a small vid of these things....I'll make another one after they break in a bit more
August 20, 200817 yr sounds real crisp on the higher notes not sure about lows camera distorts to much but its probably loud. do you have a meter or know someone who can check it love to know 25 30 35 40 45hz readings to see how its response is in that design
August 21, 200817 yr Author there is not much SQ with a Sony Cyber-shot..the mics on them are junkhere is another vidhttp://www.youtube.com/watch?v=ZO6ZP0Wr9es I had the Termlab on it this morning...it hit 126db at 10hz and climbed up to141db at 32hz..... this was with a flat eq setting with the mic 12" from thepassenger pillar and 3" off the dash....not bad at all from a trunk carwith some more break in time the batteries fully charged and some adjustmentsI can squeek a bit more out....I'll re mic it in a week or so
