How would this sound in an extended 3 door 4x4 firing up? If it would do half of what your test vehicle did. I want it!!!... :drink40:
  • Replies 111
  • Views 30.2k
  • That would be considered a T-Line correct?
  • I am done playing with this enclosure.... this one is for sale...I will let it go for $75 plus shipping
  • Figured no one would mind if I bumped this old thread. Had a question about it from someone and wanted to chime in.. This isnt a horn. It is really just a 'tapped' version of a vented enclosure. Doesn
I got an extra box...a set of 10" and a buddy with a chevy ext cab
give me a day or two and I'll have an answer for that question
Thx
do you still have this box for sale?
couldn't leave this one plain wood...have an itch for something different
let me know if you still want to sale box, thanks
the first test box is still for sale.....contact me direct at [email protected]
wow awesome paint work there damn thats inpressive! all looks extremlly good too.
Any chance of seeing what this sounds like firing up in an extended cab pickup?
Thanks
no chance to get it in the extra cab yet
got the 2nd test box installed......
the sound is very tight and detailed....a noticable drop in out put but the low end extension
is very solid....the F3 imo is slightly high with the extra .25cf3
I'll be building another one with 2.0cf3 (1.0cf3 per sub) and 33hz tuning
I have a couple questions for you....
1. What did you use to paint it? Spray like a car? Brush? I got a build coming up and I have plans to paint it but want to know how to make it look super nice.
2. What software do you use? I end up designing and building more boxes than I ever thought I would and I would like some more programs to help..
BTW NICE FVCKING BOX!!! I saw the 1st one the other day over here, then the new one on ROE now here. Man thats an awesome idea, and box. Love the loaded port, or folded triangle horn or whatever you are going to call it. Good wk man
my rear seat is a kevlar mesh blow thru and the rear deck is cut out so this basically unloads directly into the cabin....
very nice woddworking skills and finsh
Paint looks nice!!!
Is this the car that did 140db at 24hz?
Very nice work!!
lost a little out put but it hits higher in the 20hz range
Thanks
I have the 35hz box in a chevy x cab with a pair of EFX 10" woofers with 400w rms to each sub...
the enclosure is firing towards the drivers side with the port at the top and the woofers firing
up at an angle
WHOLLY CRAP!!!!!.....the two 10" sound better and get louder than his origional 4 woofer box
by a long shot
can't up fire because of the amp rack getting in the way
Nice!...
Is the box universal as far as using different brands of subwoofers? Or was it designed around the Icon specs? Only reason I ask is I have no Icons but have other 10" subs sitting around at home.
