I want to know how do they get 66 Voltage in a car. I mean I am going to get a 300 amp alt, and two power master D3100, and a SAZ-3000D. How in the world can I find out how much Voltage am I going to give out before I purchase all these things. Also how is it possible to put the amp at .5 ohms? I don't know a lot about car audio, but this voltage thing is REALLY confusing me.
The 66 volts is the output voltage of the amp, not the voltage of the car.
You can put the ohm load at .5 ohms by wiring a 2 subs that are dual 2 ohm voicecoils and wiring them in parallel. That just means hooking all the positives together and all the negatives together.
Your on the right track with the eqiupment you are looking to buy, but If I were you I would read up on some basic electronics to help familiarize yourself with what you are about to jump into.
http://www.bcae1.com/
Edited by sonic
Learn alot about electricity and amps before buying a 3000 watt amp and running it at .5 ohm!!!
Sorry fellas, this is what scares me in this biz. I would not even think about selling a 3000D to someone that I didnt verbally talk to before hand....a 3000D or any 3000wrms amp is not something to "play" around with. Please sir research and look up basic electrical info before you consider buying anything. Please!
yeah you're going to need a nice beefy electrical system to run that amp at 1 ohm, let alone .5 ohms. that alt should hold it tho. they recommend a 200 amp alt, which that covers, plus 100 other amps for the car B)
I am getting powerful sub. That is why I am getting this amp. Also I have seen small to big sub, but the only guy that owns a car sterio is not that good. I want electricity of the car to be perfect that is why I am asking you guys. Also I just wanted to know about .5ohms I am going to use it by 1ohms.
So A 300 AMP FUSE, AND 200 AMP ALT WOULD DO PERFECT? I WOULD LOVE TO GET THE 200 AMP ALT. ALSO I WANT TO HAE A 14.4 V ELECTRICITY, SO WHAT DO I NEED?
I WOULD LOVE TO TALK TO SOMEBUDY VERBALLY, WE COULD DO IT ON SKYPE. LET ME KNOW. ALOS I MIGH GE TA WEBCAM IF THAT HELP (IT PROBEBLY WOUNT).
Edited by john117
