Posted May 24, 200817 yr I was wanting to know when the 2000d model amp is coming out. Im piecing my system now and am goin to be buying an amp in about 1 month. Was wanting to get SAZ-2000D amp, but if its now out in time I will get the AQ2200D
May 24, 200817 yr My bet is that the sundown 2000d would be similar to the IA 20.1, but thats just an assumption.
May 25, 200817 yr Should be stronger by somewhat then the 20.1. Iirc sundownz got almost 3000 out of it
May 25, 200817 yr Should be stronger by somewhat then the 20.1. Iirc sundownz got almost 3000 out of itDammm thats some good power...............Aloha
May 25, 200817 yr Its not supposed to be out until the end of the year. A Sundown saz-1500d should hold you over til then.
May 25, 200817 yr Indeed - the 2000D is still a good bit away - the end of the year is likely about right.It is actually quite different from the IA 20.1 design - it's more like a scaled up SAZ-1500D.
May 25, 200817 yr ^^^^^^^I do too. I cant wait to get one. Timing might suck though,as it may be christmas time by then and all my $ will be wraped up in the family ehh
