got a tahoe,need to know what xxx setup to go with,either 2 xxx 15's,3xxx 15's,4 xxx 15's,2 xxx 18's or 3 xxx 18's,help me choose one pls. :ph34r:
wow at least you know what sub you want, but are you going to compete or show?
What are you trying to do?
and a few of those setups, youd hafta give up tons of space to do
in a tahoe...2 -15's are sick loud...put 1500wrms on each one..
or 4-12's...still just need 3000wrms..
and like mentioned above...major electrical overhaul...hehe
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee :slayer:
i think a 15 is 320 and an 18 is 369. not sure about the 15 but the 18 is def 369.
  • 2 weeks later...
out of those, the only ones i'd consider would be either the (2) 15's, (4) 15's, or (2) 18's just to keep the final load even.
the pair of 15's would more than likely get loud as you would ever want. the pair of 18's would be obscenely loud.
now that i think about it, i wouldnt even consider the 4 15's unless it was for either show, or pure competition. you wouldnt even use the full potential of that setup EVER in a daily situation, especially if you put over 1kw on each one.
