Posted October 21, 200421 yr got a tahoe,need to know what xxx setup to go with,either 2 xxx 15's,3xxx 15's,4 xxx 15's,2 xxx 18's or 3 xxx 18's,help me choose one pls. :ph34r:
October 21, 200421 yr Admin wow at least you know what sub you want, but are you going to compete or show?
October 21, 200421 yr What amps will you be using?Plan on a MAJOR electrical system upgrade?Willing to give up the entire cargo bay?Will this stereo be used daily?I'm sure we'll be able to help you make the best choice for your situation.- Steve
October 21, 200421 yr What are you trying to do?and a few of those setups, youd hafta give up tons of space to do
October 21, 200421 yr in a tahoe...2 -15's are sick loud...put 1500wrms on each one..or 4-12's...still just need 3000wrms..and like mentioned above...major electrical overhaul...hehewheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
October 27, 200421 yr i think a 15 is 320 and an 18 is 369. not sure about the 15 but the 18 is def 369.
November 9, 200420 yr funny to watch a guys 1st post about xxx's and you all go nuts hehe..Anyway man, why in the world would you want an odd # of subs?
November 9, 200420 yr out of those, the only ones i'd consider would be either the (2) 15's, (4) 15's, or (2) 18's just to keep the final load even. the pair of 15's would more than likely get loud as you would ever want. the pair of 18's would be obscenely loud. now that i think about it, i wouldnt even consider the 4 15's unless it was for either show, or pure competition. you wouldnt even use the full potential of that setup EVER in a daily situation, especially if you put over 1kw on each one.
