Posted May 29, 200818 yr Will A Custom Made Box For My 3 15'' BL's (Ported) Fit In My Contour Because Its Gonna Be Custom Made? How Much Will It Cost(420 Max.)FI.BL's (BL15)https://ssl.perfora.net/www.ficaraudio.com/...view.shopscriptMy Trunkhttp://www.altfuels.org/events/autoshow/gr...cs/cngtrunk.jpgP.S:This Isnt My Car (Above) But The Same Model Different Color. I Will Put Pics Of My Car & Trunk When I Get A New Camera. But I Wanted To Know If Three 15'' FI.BL's In A Ported Enclosure Can Fit In This Trunk Depending On How I Put It In?The Bad Thing Is People Said The Enclosure Is Gonna Be Big And I Will Have To Let Down My Back Seat To Put It In. But I Just Noticed About Something Really Good About The ''HUGE'' Enclosure Im Buying A Alarm But If Someone Gets Through It The Enclosure Is Gonna Be So Big They Cant Take It Out Right? Plus Its Gonna Take A Group Of People In Order To Take It Out Because Its Heavy!!!!Also I Can Lock My Trunk So If You Pull The Level In The Car Your Can Hear The Trunk Make That Open Noise But It Only Opens With The Key (Smart!!!) And If They Decide To Jack My Car Im Buying A Tracking Device So I Know Where My Car Is @ All Times. I Love My Audio To Much In Order To Get It Stole. If You Fell Me.''Hope This Helepd!''
May 29, 200818 yr Woah, every word doesn't need to be capitalized, it hurts my eyes. And if its custom made, then in theory it should fit. Unless it was custom made to someone elses trunk. The better question is, will it have enough volume, that is, will it have enough airspace inside. For that, look at the recommended volume for one 15" and multiply it by three. I believe the recommended volume is around 3-5 cu. ft. So you should have about 9-15 cu. ft. in your trunk if you want your subs to sound good. Do some measurements and run the numbers. And please, dont capitalize Every Single Word. Thank you.
May 29, 200818 yr i do not think it will fit... my mom owned that type of car years ago,,, and i recall the trunk.. not enough space to run them correctly. damn sure not three of them.. you would be lucky to get two...\ again why three. o yeah.. i have two of the bl 15's and my box loaded is close to 250 lbs no one is walking away with it.
