Posted June 3, 200817 yr Currently, I have a Memphis Mojo 4kw amp with 2 odyssey 2150 batteries + stock in a Hummer H2. I have already had to send in my amp to get fixed previously and I am trying to avoid that again. I was thinking about selling it off and buying a SAZ-3000D but I was wondering how hot they run because the only spot in my truck to mount the amp is directly behind the seat on the box which leaves about 1 inch of clearance for heat to escape.Also, the alternator is stock but I have not dropped below 12 volts at full tilt so I was wondering the output of the saz-3000d at 12v because I know the Mojo is not giving me anywhere near 4000.
June 3, 200817 yr The Sundown is definately more efficient. Installing a couple crossflow fans wouldn't hurt either.
