Posted June 4, 200818 yr This is a build for someone on another forum but I thought I'd post it here also.Boz is for an OZ Audio ME10 it is 1.25 ft^3 net tuned to 34hz using a 3" Aero. It will be double baffled. flush mount with an amp rack on top for an Autotek XS-900.4Design, the amp rack was a late addition .Wood all cutBuilding...
June 4, 200818 yr Author nice job. great sub, too. pics of it!The box isn't for me so I don't have the sub for pics, sorry.
June 5, 200818 yr Author OK, I got a little more done.Rounded over the edge of the trim piece 1/8", just enough to take the edge off.and cut the hole for the speaker terminal.
June 6, 200818 yr what type of paint do you use? do you have to put something on the mdf before applying the paint?
June 6, 200818 yr Author what type of paint do you use? do you have to put something on the mdf before applying the paint?I used Rust-oleum primer and paintYou need to make sure you prime the MDF before painting. The surface of the MDF isn't as bad but the cut ends will really suck up the paint so priming it will save you a lot of time and paint.
June 6, 200818 yr Ok thanks alot.....I just built my first box and I was looking for ideas on finishing it and painting it seems to be the best idea.
June 10, 200818 yr Author Box is *almost* done.Just need to cut the aero to length and install and install the speaker terminal.
June 15, 200817 yr Author It's done!!!! This is not the sub that is going in it, i just used it for pics.
June 15, 200817 yr I like how the back side of the port is painted white. This is great attention to detail.
June 16, 200817 yr I like how the back side of the port is painted white. This is great attention to detail. even if it was red too that would of been kool
