Posted June 7, 200818 yr I know there has been some problems with RCA cables and the amps for some reason. I am considering either of these 2 sets http://www.knukonceptz.com/productDetail.cfm?prodID=KRY4.4M or http://www.knukonceptz.com/productDetail.c...rodID=KARSS4.4MWill they both work and would you recommend one over the other?
June 7, 200818 yr I have used the Krystal RCAs before and they worked for me - I found them to be very tight, though. Hard to remove.I pretty much use something along these lines these days:http://www.partsexpress.com/pe/showdetl.cf...tnumber=185-232Very standard ends without any extra gripping features or fancy plugs... always work for me. I have several sets of these red monster RCAs.
June 7, 200818 yr the knukonceptz karma rca's worked pretty well for me... sundownz is right though.... its pretty hard to remove
June 7, 200818 yr i was thinkin about runnin the karmashrmmmbut i did spot some tsunami's on ebay that seemed pretty high endthey were callin them version 5s or somethin like thathere they arehttp://cgi.ebay.com/TSUNAMI-V10-17-ELITE-S...1QQcmdZViewItem
June 10, 200818 yr right now on my highs im using a pair of 4 channel stingers, thay work fine.. on my subs i use home made ones.
June 10, 200818 yr Monster cables, Yah... Monster as a company blows, but those cables work well.Basically an example... similar cables work nicely. I have Scosche EFX in the truck and on the test bench.
June 10, 200818 yr Monster cables, Yah... Monster as a company blows, but those cables work well.Basically an example... similar cables work nicely. I have Scosche EFX in the truck and on the test bench. walmart!
June 10, 200818 yr Monster cables, Yah... Monster as a company blows, but those cables work well.Basically an example... similar cables work nicely. I have Scosche EFX in the truck and on the test bench. walmart!These are nicer Scosche cables, not sure if you can get them @ wal-mart.
June 10, 200818 yr Monster cables, Yah... Monster as a company blows, but those cables work well.Basically an example... similar cables work nicely. I have Scosche EFX in the truck and on the test bench. walmart!These are nicer Scosche cables, not sure if you can get them @ wal-mart.I can't ever hear a difference?!?!?But agree with the Knu being tight, but thats how I like things.
June 10, 200818 yr I can't ever hear a difference?!?!?But agree with the Knu being tight, but thats how I like things. You can't hear a difference - I just like these particular Scosche cables since they have a strong jacket that is hard to damage and plugs that never cause issues with any amps
June 10, 200818 yr Author I can't ever hear a difference?!?!?But agree with the Knu being tight, but thats how I like things. You can't hear a difference - I just like these particular Scosche cables since they have a strong jacket that is hard to damage and plugs that never cause issues with any amps You don't want to get in the argument about not hearing the difference, I agree with you whole heartedly but someone who advocates $2,000/ft RCAs and speaker wire will come in and argue to the death that you can hear a difference.
June 10, 200818 yr If it has a good connector, is shielded, has decent strain relief and is well built well then a cable is a cable at that point. It is definitely not something I'd spend a lot of dough on. For convenience sake and the fact that the prices are reasonable I am a fan of Knu.
June 10, 200818 yr I agree. All of my cables have been 17 dollar Lightning Audio or Schoches. In my home theater I'm even still using some old radio shack, probably 4 dollar RCAs. Kinda want to change those out soon though, haha.
June 10, 200818 yr Author If it has a good connector, is shielded, has decent strain relief and is well built well then a cable is a cable at that point. It is definitely not something I'd spend a lot of dough on. For convenience sake and the fact that the prices are reasonable I am a fan of Knu.My thoughts exactly, but there are some crazy people out there, lol, they're generally called "Audiophiles" and they also think vinyl and tubes amps sound better
June 10, 200818 yr If it has a good connector, is shielded, has decent strain relief and is well built well then a cable is a cable at that point. It is definitely not something I'd spend a lot of dough on. For convenience sake and the fact that the prices are reasonable I am a fan of Knu.My thoughts exactly, but there are some crazy people out there, lol, they're generally called "Audiophiles" and they also think vinyl and tubes amps sound betterNow, your getting into a whole different subject with the tube amps and vinyl.
