Posted June 12, 200818 yr I want to the this sub but I dont know if my amp will over power it... It's a Power Acoustik BAMF 2000w 2ohms 900w 1ohm 1200wSSD is rated 800rms but with bp power will it be able to handle the amp?
June 12, 200818 yr You have two options.1) You can get the DVC1 sub and wire the coils in series for a 2 ohm final load.2) Get the DVC2 option, wire in parallel and go easy on the gains.You don't have to send the full 1200w to the sub.
June 12, 200818 yr Author Thanks for reply, also can you put this in a sealed box? I see that they recommend it ported
July 8, 200817 yr 1200w should be fine for an ssd. imo. if i were you id go ported if you got room! but if sealed is a must atwell told me theyll do fine
July 8, 200817 yr i donno about sendin that ssd 1200 watts daily. a clean 1000 watts maybe. i would try to stay closer to 800-900. but thats just me.
July 10, 200817 yr Admin I would suggest getting the dual 1 coils, and running a Kicker ZX 750.1. Plenty of power.
