November 6, 200421 yr I haven't seen david around lately, u must of got him on aim, or he just posted this somewhere?
November 6, 200421 yr just a thought, but wouldn't it be better if the voice coils wire where bigger, instead of them being so small?
November 7, 200421 yr well yes if u want to be technical, like a 6 or 8. That looks like 18 or something.
December 3, 200421 yr just a thought, but wouldn't it be better if the voice coils wire where bigger, instead of them being so small?<{POST_SNAPBACK}>no not really you want more wire wrapped then just bigger wire
December 4, 200421 yr The gap would have to be bigger which could cause some misalignment problems too.
September 3, 200520 yr well yes if u want to be technical, like a 6 or 8. That looks like 18 or something.<{POST_SNAPBACK}>I know this was asked a while ago, but I thought I would add the answer. Remember that BL is B times L. B is the magnetic flux seen by the coil, and L is the length of wire effected by the magnetic flux. If you make the wire larger, you change quite a few properties of the subwoofer. For one thing, it becomes more difficult to stack the same length of wire in the gap. You also effect the moving mass, DC resistance, inductance, and as mentioned earlier BL which will effect other parameters from there. And the question comes up of why? Thermal handling isn't a major issue with the smaller awg wire typically used currently. So if it aint broke, why go through all the trouble of trying to fix it? Steven KephartAdire Audio
February 23, 200718 yr Nice video showing a speaker built from start to finish. Edited February 23, 200718 yr by DevilDriver
