January 22, 200521 yr All size(10,12,15) Adire Brahmas have 29 mm XMAX. Oh and accuracy has a lot more to do with enclosure than with the size of the sub. Although the smaller subs can typically play the upper bass with more authority and the larger ones can play the lower bass with authority(typically)
January 22, 200521 yr All size(10,12,15) Adire Brahmas have 29 mm XMAX. Oh and accuracy has a lot more to do with enclosure than with the size of the sub. Although the smaller subs can typically play the upper bass with more authority and the larger ones can play the lower bass with authority(typically)<{POST_SNAPBACK}>hmm good analogy...i havent looked at it from that perspectivethanx
January 23, 200521 yr welcome to SSA 80<{POST_SNAPBACK}>thanx.......its good 2 talk 2 folks who understand car audio as a whole.....i've been into car audio since i was nine..then i realize tht i have an addiction ..i addicted 2 bass....and i hope theres no cure...lol80
