Posted July 12, 200817 yr Hey guys ive had an AX4300 for about a year now and one of my channels doesn't work properly.It seems that the rear right channel will give a very scratchy sound like the speaker is blown. i went back and checked the RCAs and they were plugged in fine. if i jiggled the rca or pushed it in harder it would clear up for a while but then the sound comes back.What is going on and how can i fix it!!?!Thank you
July 12, 200817 yr Admin Did you check the connection at the speaker itself? Also, RCA connection at the head unit?
July 14, 200817 yr Admin Did you try hooking the speaker up to one of the other channels to make sure it is not the speaker?
July 15, 200817 yr Author yep. as of now the two rear speakers are running at 2 ohms off of one channel.
