Posted July 19, 200818 yr just got my new fi ssd 12 dual 2 with copper coil & bp power. was planning on going with a sealed box 1.1 cu and thinking bout getting audioque 1200d. will that amp be ok? to many watts? any help greatly appreacited. suggestions? amp? box? listen to everything but mostly rock. going in f150 super cab.
July 19, 200818 yr Author i know wattage rateings are almost always misleading. but that amp cost quite a bit more for less rated watts. not really a problem but is the extra money worth it? does it match the sub better? i learned real quick in this do your homework before you buy. you guys know not me. thanks
July 19, 200818 yr ah ha... thank you! yes you are correct with most companys thay do OVER RATE or rate at 14.4 volts..... well sundown rates at 12 volts... thus..it is allways what it says it will be... the sae 1000d is a 1k@1ohm@12v the saz 1500 is 1500 watts at 1 ohmat 12volts.. ans guess what.... the saz 3000d is 3000 watts at 1 ohm at 12 volts.... and 4700ish at 16 volts.@1 ohm.. you can also find those amps used... or even for a great price on a new one email SSASALES> good job by the way o yeah.. sundown has THE BEST customer relations..... and i do mean THE BEST> buy KNWOING you have a great product and AlWAYS be taken care of......
July 20, 200818 yr Author yea thats what i was wondering. thanks for the info sundown looks awesom. ready to get started on my build now if it wasn't so dam HOT outside. lol thanks again
July 20, 200818 yr i feel your pain... the heat index the whole week last week was over 100 and this week is suppose to be the same
