Posted July 25, 200818 yr Ok i am bout to purchase my first audio system. but i had a quick question. Is it really neccesery to purchase Component speakers and a Amp for them. Or can i just use my Manufacture speaker.... If i Just use my manu facture speakers. Do i Just run them to my head unit or wat
July 25, 200818 yr Is it really neccesery to purchase Component speakers and a Amp for them.If you're looking for undistorted output in any meaningful way, yes.
July 25, 200818 yr lincoln factory speakers are very nice... i think it depends on the type of car (spreakers).... unless your a SQ head... then,.... ill shut muh mouf
July 25, 200818 yr Depends on your goals, likes, skill level, and ultimately, budget.Just having better drivers doesn't mean it will sound better. You will hear a common phrase used; "it's all in the install." Heed this information as it can make or break your entire system.
July 25, 200818 yr Admin To me, it is always worth it. Heck, even if you get just a small 40x2 amplifier, and some passive components from a major name (Cadence or Kicker for example) and do just a little sound deadening on the door while you have the door panel off to install the new speakers, the difference would be pretty solid.
