Posted December 11, 200421 yr I am curious, alot of infinity subs and solobarics and such call for a pretty small ported enclosure volume (less than 1.5 cuft for a 10)If a sub has a recommended enclosure volume for a vented box of 1 cuft, what would happen if you put that sub in a 1.75 cuft enclosure?
December 11, 200421 yr Admin this is a lesson in sub woofer efficency that I am not the best person to explain
December 11, 200421 yr while this won't be the best answer, i'll give it my best.by putting the sub in the larger box, u loosen up the suspension, ie: it now needs less power to reach full xmax. thus making it more efficient. this does have a drawback...because the sub can reach xmax with less power, u can't give it as much power. and if u try, u risk pushing the sub beyond it's mechanical limits.while that's not the whole story, it's the core. there is the amp's ability to control the sub, port volume and just how much bigger the box is that plays a role in it.but i hope i answered ur question well enuff to help. and remeber, bigger isn't always better.well, at least with sub enclosures......hehehahaha wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 12, 200421 yr There is also more positive things for a bigger box.It will give your woofer much better low end play. THe bigger the box, the most likely the lower it will play depending on port size and tuning.My XXX 18" calls for a 7.5 CF box, but its sitting in a 10.7 CF box 9.8 after displacement. LOW spl is the only thing for me
December 12, 200421 yr Using BassBox 6 Pro to provide visuals of what the effects of a larger enclosure are, first let's state our set-up ...Kicker S10L741.75 ft^3 tuned to 48.2 Hz (Street Bass - Kicker spec) Now we double the size to 3.5 ft^3, keeping the tuning frequency and port area the same ...
December 13, 200421 yr Author that even answered the question betterYou guys have to be the most knowledgeable people I've ever met in the area of car audio!
December 13, 200421 yr I would've explained it, but it wouldn't let me edit my post ... And it was late, so I just said fudge it Now I'm too lazy ...
December 13, 200421 yr It has been my experience that larger boxes play lower. I had a 2 cubic foot box tuned to 35 hz and my friend had a 9 cubic foot box tuned to 35 hz and the lows in his were way more evident and defined. But basically, like mrray13 said, the sub is able to reach xmax easier in a bigger box which raises efficiency and lowers power handeling. If you have a bigger amp- use a smaller box. If you have a smaller amp- use a bigger box. That is how the Shiva and Tempest work so well in HT applications with small wattage. They recommend huge boxes which allow them to reach full potential with 200 watts.
December 13, 200421 yr That would be because the larger enclosure moves the peak closer to tuning and increases the size of the peak ...FYI, low-to-mid-30s is LOW Late Night Tip, Lil' Jon, etc. are all in the low-30s ...If you were to take the same enclosures and play 20 Hz test tones at full power, I guarantee the smaller enclosure wins
December 14, 200421 yr any more thoughts on this---I wanna say my pieceno, no..go ahead.... my post pretty much explained all i know (or think i know) about the subject. so release some of ur knowledge already!!! wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
December 14, 200421 yr That would be because the larger enclosure moves the peak closer to tuning and increases the size of the peak ...<{POST_SNAPBACK}>I guess that makes sense. Thanks for clearing that up.
December 15, 200421 yr Author any more thoughts on this---I wanna say my piece<{POST_SNAPBACK}>I wanna hear your piece
December 16, 200421 yr I will say that there is alot of good points bought up on this topic---one of the best reasons for a larger enclosure is less power is needed to power the sub----which saves the electrical system-----plus you can add more port area easier to a larger enclosure----the other is deeper transist response----I think all you guys hit the nail on the head and pretty much covered everything. mrray13 is right in saying that it lowers powerhandling and increases eff. now I will shut up
December 19, 200421 yr Yes he is, but I know everything about nothing. and i know nothing about everything wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
January 23, 200520 yr ok i'll put alittle spin on this....what about a small box with a long port...i've seen that be for...and the sound is different
January 23, 200520 yr Smaller boxes need significantly longer ports than larger boxes. If you look at the formula you will see this.
January 24, 200520 yr I'M ON MY COMP PLAYING AROUND WITH MY BASS BOX PROGRAM ...DESIGNING BOXES FOR XXX AND BRAHMA SUBS.MY GOAL IS TAKE A SUB AND SEE IF HAS THE POTENTIAL TO HIT AT LEAST 145DB's BEWTWEEN 25 TO 30HZI THINK ITS POSSIBLE...CONSIDERING THAT I'VE MANAGEDTO HAVE A TWO 10XXX HIT 139DB @ 26HZ...AND I'M NOT SURE IF THIS ACTUALY HAPPENS BUT MY PROGRAM SAID ITS ONLY USING .18IN OF XMAX OUT OF A POSSIBLE 1.26IN ONE WAY XMAX....THATS IMPRESSIVE FOR TWO 10XXX.THE BOX I MADE UP IS 2.41CUFT. EXTERNALAND 1.77CUFT. INTERNAL...THE PORT IS TUNED TO 25.84HZ11.5H x 1.5w x 40D YES THE BOX IS A TRANSMISSION LINETHATS WHY THE PORT IS SO LONG..ITS BROKEN UP INSIDE THE BOX TO FILTER OUT THE UPPER FREQ. SO WHEN THE BASS FINALLY COMES OUT ITS VERY DEEP AND FULL.I PUT A SUPPLY POWER OF 1000W...AND THE SUBS STAY LINEAR DOWN TO 5HZ...THATS COOL80AGAIN JUST MESSIN AROUND WITH DIFFERENT DESIGNS
