Posted August 7, 200818 yr good evening . ive bought a Ascendant audio mayhem 15 dvc 2.now is my question in what size of box it will operate it best.y want a ported box tuned between the 40 and 45 hz yust allround music tuned.here are the t&shttp://www.bladeice.com/mayhem.phpand how much diverence makes it to makes it lower.y mean is the size of the box the same as on higher freqs like above.and y have to change only the port .y hope you can help me.y heard allready 2 difrent sizes so y hope you can help me to make tje right choisethanks allready grtz erwin.
August 7, 200818 yr Ported box we recommend using 3-5 cubic feet @ 30-35Hz. Again use 12-16 square inches of vent area per cubic foot of volume.
August 8, 200817 yr Author ok thanks . and how long is the size of the port ? than y can build a box is it around the 15 inch ore shorter.of is that just testing what the best size is.thanks fore so far
August 8, 200817 yr Post up the maximum dimensions your box can be and someone will help you with a design.Port size and length will be defined by the box size. . . Brian
October 25, 200817 yr Author and the van of a friend of myand some broken car partsa few movieshttp://www.youtube.com/watch?v=6w77gjwarx8http://www.youtube.com/watch?v=Gao2qRFNpaohttp://www.youtube.com/watch?v=1xYIuZRmVyohttp://www.youtube.com/watch?v=Qw_mCkIqa3whttp://www.youtube.com/watch?v=p2UUrZlMRbEhttp://www.youtube.com/watch?v=cnyPid1h7UEhttp://www.youtube.com/watch?v=UwoumgdZLuU[]
October 28, 200817 yr Author y can have 4 a 4,5 cf in my booth.so whats the best port size @ around 35 hz.thanks already grtz erwin
November 11, 200817 yr At 4 to 4.5 ft of net volume, you need 55-70 sq inches of port. The length will be determined by the port dimensions and tuning frequency. Hard to determine a good port without knowning the max dimensions of the box.
November 12, 200817 yr i sware the havocs are the sexiest subs alive Are the Havoc cones like the JL Audio "W" cone.
November 12, 200817 yr Depends on what you want to achieve.I've found 4.5cubes tuned to 33hz to give excellent slam and impact. Great for rap music.If your playing dirty chopped and screwed remixs, try 5.5-6cubes tuned to 30hz, it'll defo move some serious air around the 25-33hz area
November 12, 200817 yr Author y listen r&b and normal music y like to have it tuned around the 35 a 40 hz.y have 4 cf of space in the booth.so i can do " At 4 to 4.5 ft of net volume, you need 55-70 sq inches of port"and al lenght around the 16 inch?thanks fore the help so far
