Posted August 12, 200818 yr I have a Nissan 350Z and I have ordered a 180amp HO alternator from Ohio Gen to go along with a Kinetik HC1400 under the hood. Do you think that'll be sufficient to power one SAZ-1500D (1ohm 1500W), one SAX-100.4 (bridged 320Wx2), and one SAX-100.2 (stereo 100Wx2)? I already have the "Big 3" done as well. I refuse to run Capacitors so please don't even bother suggesting one. Edited August 12, 200818 yr by B5I8
August 12, 200818 yr Author IMO, that will be pushing it.The only other thing I can do is add another battery. The 180amp alt is the biggest they make.
August 12, 200818 yr If you add another battery, I think you'll be fine. At least a HC2000 or HC2400 if you wanna stay with Kinetik.
August 12, 200818 yr i think you shouldnt have any problems at allmy electrical consists of a 90A alt, 2/0 wiring and 2 optima yellowtopswith 1 saz3000d and a blaupunkt velocity burning desire 1 my voltage isnt dropping under 12,2V even with the car NOT running
August 12, 200818 yr Author I don't play my system with my car off so I think I might try it like this for while. In the future I may add another battery if I feel I need it. Thanks for the responses.
August 12, 200818 yr make it easy, get a voltmeterif the voltage realy is dropping low, you can get a bigger battery
August 12, 200818 yr you should be fine that Ohio Gen is alot stronger than 180 amps Ive got a 160 amp and when they tested it it maxed out at 224 amps
August 12, 200818 yr Author you should be fine that Ohio Gen is alot stronger than 180 amps Ive got a 160 amp and when they tested it it maxed out at 224 ampsThat's good to know. I like that all their alts come with a birth sheet.
August 12, 200818 yr i think you shouldnt have any problems at allmy electrical consists of a 90A alt, 2/0 wiring and 2 optima yellowtopswith 1 saz3000d and a blaupunkt velocity burning desire 1 my voltage isnt dropping under 12,2V even with the car NOT runningimo this is not enough.
August 12, 200818 yr I have a Nissan 350Z and I have ordered a 180amp HO alternator from Ohio Gen to go along with a Kinetik HC1400 under the hood. Do you think that'll be sufficient to power one SAZ-1500D (1ohm 1500W), one SAX-100.4 (bridged 320Wx2), and one SAX-100.2 (stereo 100Wx2)? I already have the "Big 3" done as well. I refuse to run Capacitors so please don't even bother suggesting one.You will be good unless you plan on running the 1500d at 1/2 ohm and all of the SAX amps at 2 ohms and frequently abuse them.You could add an HC600 or HC800 in the trunk for a little extra juice but its not really needed.i think you shouldnt have any problems at allmy electrical consists of a 90A alt, 2/0 wiring and 2 optima yellowtopswith 1 saz3000d and a blaupunkt velocity burning desire 1 my voltage isnt dropping under 12,2V even with the car NOT runningYou def need more current than that.
August 13, 200818 yr Author Thanks for the replies fellas. It seems the consensus is that I should be okay. If not, I may need to add another battery but it doesn't have to be the biggest honking battery that money can buy.
August 13, 200818 yr i think you shouldnt have any problems at allmy electrical consists of a 90A alt, 2/0 wiring and 2 optima yellowtopswith 1 saz3000d and a blaupunkt velocity burning desire 1 my voltage isnt dropping under 12,2V even with the car NOT runningYou def need more current than that.i will change the 2 optimas to Hawker Datasafe HX400, that has to be enough to feed 2 3000d's for ~3-4secondsim in a class where i am only allowed to have 2 batterys and i am not allowed to let the car run while doing the burpand as long as i dont have any big voltage drops, i dont see any problem?
August 13, 200818 yr i know that 150 amp hours each 3000d is what jacob calls for. your spl car is a 300z... sweet
August 13, 200818 yr Author i know that 150 amp hours each 3000d is what jacob calls for. your spl car is a 300z... sweet350Z. It's not an SPL car, it's my daily driver. It's more like a LSQ car as I'm running a set of SEAS Lotus Reference up front and just two 10's in the hatch.
August 16, 200818 yr i know that 150 amp hours each 3000d is what jacob calls for. your spl car is a 300z... sweet350Z. It's not an SPL car, it's my daily driver. It's more like a LSQ car as I'm running a set of SEAS Lotus Reference up front and just two 10's in the hatch.Sweet ride with kick-ass system. I run a bit less power with 120A alt, and have no voltage drop issues even at full blast while driving. Drops a bit at idle, and drops even more if I use AC. It looks like you should be more than OK as is with your battery and 180A alt.
August 17, 200818 yr I have a 140 amp alt in my 1985 Cutlass and a single yellow top and I run a 3000D and a PPI ProMos-450 with hardly any dimming or voltage drop. (.3 volts)You should be fine. Edited August 17, 200818 yr by Grinder1989
