im looking to redo my set up. want to go with all sundown amps this time. will eventually go active or use the 3/4 chanels fo mid bass. after i buy my saz1500 & subs but until then can i use my 1/2 chns to run my comps passive and bridge 3/4 at 2 ohms on a small sub? or does it have to be at 4ohm? and what type of output can i get out of the bridged chns at each ohm load. i going to order the new heatsink model by the way.
Edited by soundjunkie
You are in pretty much the same boat as I am. I currently have a 100.4 and plan on a 1500 in the future (and plan on the 250.2 *cough**cough*Sundown*cough*) but until then, you can run your comps passive and bridge 3/4 for 360W @ 4 ohms for your sub
I'm trying on the 250.2 - I am getting such a surge in demand for existing products that all of my capital is going into more inventory for those items. Also trying to release the 2000D and 50.4 models as well in addition to all kinds of other stuff - working as hard as I can :)
My solution to needing a 250.2 was to bridge a 100.4.
so i can get 100wt x 2 for my comps and how does the amp do 360wt bridged 3-4?
You are a very smart man!
