Posted August 20, 200818 yr my sub is wired to one ohm. How do I wire my pos and neg speaker wires to the amp? Can I go from the positive terminal on one side to the net on the other?
August 21, 200818 yr I think what you are asking is what terminals on the amp to use, correct? The positive and negatives on the mono amps are connected together inside the amp so it doesn't matter which ones you use. Just use the ones that are easiest for you.
