Posted August 22, 200817 yr amp is a orion 1200d, space aval is 4.00 cuft listen to 95% rap musicso which should get louder and hit lowest 2 12'' si bm's or thje 15'' bl?
August 22, 200817 yr You seem slightly confused on your goals. The BM's are shallow mount SQ subwoofers while the BL would be considered a Ground Pounder.Just stick with the BL if you have that much space available. Do a ported box and tune to around 35-37hz.
August 22, 200817 yr Admin I agree with John. I would strongly lean towards the BL in this situation.
