Posted August 22, 200818 yr I am doin some searchin and plan on posting a lot of amps on here with peoples feedback to them and hee is the first to start-Bazooka MGA11500HThis amp has been specifically optimized to produce it's most power @2ohms but still be 1ohm stable! What is so good about this is when your impedance curve rises over areas that you wish were louder, this amp will pretty much make that happen.For example - wire a sub to 1 ohm, put it on a 1ohm amp, it will not hit the 1 ohm mark on the amp but on average may hover around 2 ohms. This isn't exact science obviously but you get the picture.So, the specs for this amp-810w @4ohms1,550w @2ohms1,222w @1ohmComes with advanced protection circuitry to alert users of potential dangers before they happen, strappable, comes with plenty of tuning capabilities and comes with the capability of being water-cooled.Recommended to use 200A fuse per amp.Price - under $200 shipped, Retail - $500Now... tell me, this sounds too good to be true for the price but what do you guys think?It says it's class H but i have no idea how that compares to D. I'm assumig it's less efficient if it requires a 200A fuse for a 1,550w amp.
August 23, 200818 yr The best amps for the money........... Easy answer Sundown Audio FTW Edited August 23, 200818 yr by 1qwikstang
August 23, 200818 yr Author Looking at another one-Autotek SS1900.1D1000w @ 4ohm1500w @ 2ohm1900w @ 1ohmPrice - Under $400JBL GTO140011200w @ 4ohm1500w @ 2ohmPrice - under $400
August 23, 200818 yr Admin The Sundowns are for sure. The PG RSD's are also up there for performance per dollar. In additon to Cadence.http://www.diymobileaudio.com/forum/showthread.php?t=43676
August 23, 200818 yr My hamster on a wheel connected to a few wires and light bulbs.Hey now, that sounds a lot like my amps
August 23, 200818 yr I'm going to vote Sundown on this one too...I love my 3K, and it's not even installed yet!
August 23, 200818 yr also eclipses xa series are pretty good for the money. no real high powered amps but the xa4000 125x4 @4ohm for 200 bucks thats not to bad.
August 23, 200818 yr so far all you have is medium power level amps how about higher power levels like 4-6kw something good for comps but can handle daily abuse provided you have the electrical. possible ma audio hk4000d over rated but can be had on ebay cheap for the power proven in comps idk about daily
August 23, 200818 yr Medium power, Unless you have an 18V secondary circuit in your daily driven vehicle, the HK4000D is not going to be the best choice...regardless of the smarts about using 4kW every day anyway.
August 23, 200818 yr as long as you keep voltage above 10.5v i believe they stay on so a strong alt and big battery bank should be fine for one. my buddy has one he uses for comps runs it off a hc2400 and a yellow top. powers 2 10bl's in a blazer and can do 149's consistantly. i know about ten other guys using them some using 16v systems some 12v none 18v
August 23, 200818 yr ditch the bazooka we had some at work and they do not perform. Period. The last time I saw some one buy something like that the amp was used and lasted for about a day. If it sounds to good to be true it probably is. I heard nothing but good news about the sundowns a buddy is getting some for his BTL's
August 23, 200818 yr ditch the bazooka we had some at work and they do not perform. Period. The last time I saw some one buy something like that the amp was used and lasted for about a day. If it sounds to good to be true it probably is. I heard nothing but good news about the sundowns a buddy is getting some for his BTL'sDon't forget the excellent service and support you get from Jacob at Sundown. This can't be overstated.
August 25, 200818 yr in my opinion, i would have to say Cadence. I have a couple of em, never had a problem, put out very close to stated rms, were very cheap( 200$ for 1000w rms, and 99$ for 75wrms x 4), fairly efficient, never ever get hot, and are built like f'n tanks.
August 25, 200818 yr so far all you have is medium power level amps how about higher power levels like 4-6kw something good for comps but can handle daily abuse provided you have the electrical. possible ma audio hk4000d over rated but can be had on ebay cheap for the power proven in comps idk about dailyMA is a decent amp, my friend has 4 of them running off a bank of 16v Turbostarts, just runs it on stock 13,14volt on the street and plugs all the 16v into a charger when he is gonna be competing. with 2 x 12" MT's and a relatively small box, probably 4 to 5 cubes, he is doing 157 on TL. not sure what he is doing off normal alternator/battery power or if he triedfor the money, i thin lanzar makes pretty decent stuff, and for dirt cheap used amps, the tsunami GXA1000 was pretty good, i got 2 off ebay a few years back for 50, maybe 60 bucks each
August 25, 200818 yr manufacturer authorized refurbs, got my old heatsink sundown 1500 for $360 from db-r, thats a deal
August 25, 200818 yr I think this thread is a waste, the idea is good; however, with no organization you are just going to get boner replies. Answering "this brand" is a useless response considering most brands have some good pieces and some junk. Not all of them are into all quality designs like the Sundowns.
August 25, 200818 yr Author This is why i started the thread with a specific model and other replies i've done with specific models as well.This is true, many brands carry crap, ok, decent and great lines. Many of us are used to that.I know that the sundown amps are all basically on the same level of great without questioning but for the models out there that need questioning... that's what this thread is about.
August 25, 200818 yr The best amps for the money........... Easy answer Sundown Audio FTWSunDown x2 just my .02centsbut i am Bias as i WIN a Lot of 1st place Trophys with SD SAZ 3000d powering the Beast...thats me in the Sundown T-shirt
August 27, 200818 yr Admin I agree, if there were parameters set then we could gain more out of the topic. Such as, utmost power and reliability, or features and flexibility, or pure clean unfiltered sound, so on so on.
