Posted August 29, 200818 yr so Ive been workin on my daily driver and what will probably be my tow vehicle if needed today. the plans areEclipse CD3100Image Dynamics CTX6.5 coax speakersSundown audio SAX-100.4and a pair of Sundown audio SD-1 V1 12sof corse the coaxs and subs are going to be ran off the 100.4CD3100 installedcoaxs installedIve still gotta run the 1/0g wire and hook up the 100.4 tomorrow before workalso Ive still gotta build the box for the subs too and the truck needs a major clean up Ill probably end up steam cleaning the seats and cleaning up the vynal flooring its got in it. the flooring will probably get trashed and swapped out for carpet late this year or early next year
August 29, 200818 yr Author Looks good.the doors will probably need deadened Ive got a gallon of SS sludge that Im going to put on the rear deck of the car and Ill probably have enough left to do the doors. alot of the work is going to be cleaning it up my Dad had it till a few months ago and he used it as a work truck if you cant tell by all the dirt it didnt get cleaned up very often so its alot of work for me fortunatly Im not allergic to it I just dont like the looks of it
August 29, 200818 yr Author OK as many of you fellow Silverado owners know its pretty much impossable to run power wire through the firewall well I just found this out so instead of using the 1/0g wire like I planned to I went up and picked up a tsunami power wire kit and some flex loom and ran it under the truck.
August 29, 200818 yr OK as many of you fellow Silverado owners know its pretty much impossable to run power wire through the firewall well I just found this out so instead of using the 1/0g wire like I planned to I went up and picked up a tsunami power wire kit and some flex loom and ran it under the truck.On an 02 there is already a grommeted hole you can use for the power wire. Easiest vehicle I have ever run power wire through the firewall on in fact.
August 29, 200818 yr Author OK as many of you fellow Silverado owners know its pretty much impossable to run power wire through the firewall well I just found this out so instead of using the 1/0g wire like I planned to I went up and picked up a tsunami power wire kit and some flex loom and ran it under the truck.On an 02 there is already a grommeted hole you can use for the power wire. Easiest vehicle I have ever run power wire through the firewall on in fact.ah I didnt see it I saw a few grommits but they appeared to be up way too high doing it this way eliminates the problem I thaught I could possably have of being able to tell that there is a wire under the flooring. honestly my 2005 cavalier was pretty easy there is a huge grommit right around the steering column I fit at one time a total of 6 runs through there
September 1, 200818 yr I think me and you are in the same boat loudcav. I've seen pictures of 02 trucks with this cool little grommet right by the master cylinder that is perfect for 1/0, but I looked on my truck today and there is no hole and its not easy to get a drill in that area.
September 1, 200818 yr Down in the drivers kick, pull out (move out of the way) the fuse/relay panelthere should be iirc a fair sized grommet, you should be able to get 1/0 through there without much issue
September 1, 200818 yr Author I think me and you are in the same boat loudcav. I've seen pictures of 02 trucks with this cool little grommet right by the master cylinder that is perfect for 1/0, but I looked on my truck today and there is no hole and its not easy to get a drill in that area.ya I looked at alot of areas and just running the wire under the truck seemed to be the safest bet since I could easily guarantee that when I drilled I wasnt going to go through anything that I didnt want to
September 1, 200818 yr Author also after weighing my options Ive decided to change subs so Im going from the planned SD-1 V1 12s to
September 1, 200818 yr also after weighing my options Ive decided to change subs so Im going from the planned SD-1 V1 12s toNICE!!!
September 1, 200818 yr Author I didn't know DD made 6.5's...ya they are a mid bass/ mid range but they are able to be used as subs in space lacking stereos
September 25, 200818 yr Author OK Ive been working on the truck a bit today working on deadening the doors just a bit. in the end Ill have 6sq feet of dynamat extreme and some Second skin Sludge on each door Ive got a lil bit less than a gallon of the sludge for the job and it should all get used.door prepped for installthe door that Ive pretty much got done all thats left to do on that one is let it cure till Sunday then Ill put the pannel back on and clean up the lil bit of sludge that I made a bit of a mess with
September 25, 200818 yr Author Ive also decided to just stick with the SD-1 12s here hopefuly next week Ill get a box built for them Im lacking a bit on space so the box is going to be around 1.4 cubes for the pair with probably 2lbs of polly fill to make up for the lack of space so hopefuly that will help. I also did a bit of ghetto math today and figured out that right not for the pair Ive only got 1.3 cubes no pollyfill and they are seprate chambers and Im fairly happy with what Ive got now but I see that Ive got alot of improvements that I can make
September 25, 200818 yr Author Ive also decided to just stick with the SD-1 12sMuch better idea. ya they are fairly impressive especialy since they were pretty much just tossed into a pair of cheap prefabs that are a hair small with not even some polly fill to make up for that. a big reason to build a new box is the comfort facter Ive gotta have the seat up a bit farther than usual and the new box the seats should go all the way back no problem
September 25, 200818 yr Author both doors are done Im going to let the doors cure for the night and most likely put the speakers back in the doors tomorrow then sunday put the door pannels back on and clean up the lil bit of a mess I made
October 12, 200818 yr Author well its finaly time to build a box for the 12s The amp finaly fell off the back wall of the cab tonight so since Ive gotta pull out the subs and boxes to do so Im just gonna build me a box
October 12, 200818 yr Author mmmm what do do I did find a bit more space today now Ive got 1.9 cubes sealed for the SD-1 12s or I could do a single sub ported with about 400 watts gotta be 4 ohm tho
