Posted September 8, 200817 yr As of today i finally have 99% of my wiring finished for my second externally regulated alt. Im going to get a volt meter of some sort so i know exactly where I'm sitting at voltage wise at all times (just in case the knob is bumped or any other unforseen issues) So for the next week or so im going to have a very small fuse on both the alt wire and amp wires just to be extra safe. I was just wondering how many of you guys are running the 3000d at 16v (18.8)? and if there's any thing i should know? I'm trying to be as cautious as possible to make sure nothing goes wrong but i thought id ask for advice from the experts
September 8, 200817 yr i'm not sure, but isn't 18.8V a lil too high for that amp... i think thats the range... like a 12 volt system charges at 14 volts.... i think a 16 volt system charges at 18 volts.
September 8, 200817 yr 18.8 might be normal for a 16V system, but 18.8 could damage the amp.. (i read that somewhere on this forum)mr sundown will have to confirm though..
September 8, 200817 yr Author that's what i'm sorta worried about. and i cant really expect much resistance with the wires since there amp is so close to the battery and i'm using 2/0 wire
September 8, 200817 yr if i remember correctly, 18.0V should be the limit... that amp will go nuts with that kind of voltage, i feeling sorry for your subs already...
September 8, 200817 yr i believe u should be fine...even though ur chargn at 18.8 i think once u start playin ur setup ..depending on how much batts u workin with...it should drop just below 18v..if ur doing 1ohms on the amp...if u doing anything lower than .5 ohms expect to be in the 15-16v range.cuz with any amp at that point u really pullin juice..good thing sundown amps r pretty efficient.80
September 8, 200817 yr Author if 18.0 is the limit i dont see an issue of running it at 18 instead of 18.8 i can always bump up the voltage for large draws and back down as necessary. Hence the necessity of the guage
September 8, 200817 yr Author sry missed ur post 80in.... im running 2 hc16v's and i have the subs wired to 1 ohm. Im probably never going to have them at .5 because they are quad wired in series inside the box and id rather not take them out again
September 8, 200817 yr Author I don't suggest over 18 volts for any sort of continuous play time.cool 18 thats what i wanted to know18.8 volts wont help you at all in comps 18 volt limitya i only do spl comps 3 times a year or so... i'm mainly concerned with daily continuous time.
September 8, 200817 yr if your mainly doing daily its kinda pointless if you ask me to step into the 16 volt realm
September 8, 200817 yr Author true but my line of thinking at the time was i figured if im going to add a second alt why notI just added the fuse for the amp and lets just say wow. I have both the gain and output control on my processor all the way down and it sounds just about even with the mids/highs
September 28, 200817 yr Author quick question for ya jacob. if the amp is at 16v does the remote need to be at 16v too?
September 28, 200817 yr quick question for ya jacob. if the amp is at 16v does the remote need to be at 16v too?Preferably the same voltage as the supply, yes.
September 28, 200817 yr Author sweet. i bet that's whats giving me issues right now. Amps been doing very good thou. Doesnt even get close to hot and im hella happy with the remote gain knob. Thanks for everything
