September 23, 200818 yr Author ?No...Cause before it was took off the site its was 1500 watts and now its only 1000.
September 23, 200818 yr Author Uh... no.It was always 1000 I promise.lolok thanks. so sence we are allready talking about the BL would a Saz 1500d Sundown be over powering it?
September 23, 200818 yr The BL's are underrated, but still take it easy on your subs!It's always good to have a little bit of headroom w/ amp power as not to clip your subs trying to push them to their full potential.But as far as adding power handling, that is what the options are for.Here read this:http://www.soundsolutionsaudio.com/forum/i...?showtopic=7154 Edited September 23, 200818 yr by nick_19
September 23, 200818 yr Author The BL's are underrated, but still take it easy on your subs!It's always good to have a little bit of headroom w/ amp power as not to clip your subs trying to push them to their full potential.But as far as adding power handling, that is what the options are for.Here read this:http://www.soundsolutionsaudio.com/forum/i...?showtopic=7154Yeah i ready that im getting all the options and i have one more question. Its about dual 1 and Dual 2 I want to run my amp at 1 Ohmshould i get dual 1 or dual 2 and wire in parallel?
September 24, 200818 yr If you are running one sub get D2 and wire parallel, if you want to achieve 1 ohm with a pair get d1's and series/parallel them
September 24, 200818 yr Author If you are running one sub get D2 and wire parallel, if you want to achieve 1 ohm with a pair get d1's and series/parallel themOk thanks
