humm... under your trunk do you have a deal inside of a plastic box? with a hose on it... check when you can...
i dont have the check engine light... but that fuel did not want to go into that tank......
why are there no pics of your car!
Sounds like your charcoal canister. They usually can only hold around 3oz of liquid (designed for vapor not liquid). Thats why you're not suppose to keep filling your tank when the pump stops the first time. this extra fuel sits on a sensor in the vent tube and causes the evap system to not work properly
It's very important to not overfill vehicles of the 2000s model years, especially the latest models for shure
That's not exactly true. What usually causes them to "burp" fuel out lik ethat is a vent line either pinched, or a vent valve is nt opening. Most of the time it's not something major, but it can be. Being that is no check engine lights on, I would bet that it is a problem somewhere with a vent. I have even seen people come in with problems of a wasp or mud-dobber building a nest in the vents before.
If it is filling the purge canister, then you have an issue with a vfent valve somewhere not working properly. But if this was the case, you'd have a check engine light on. And seeing how you don't, I doubt that would be it.
thank you.. im plan on lookin at it soon.
i was thinkin along the same lines...
I haven't taken any of my car, but here's my trunk....
the truck is that shallow? or is that a false floor?
you ran that 40.1 just off three yellows and a h/o alt?
nah, false floor, and I ran it off three batts. and oem alt. Everything was fine until I let it play for 4-5 hours with the car off. Me and my buddies were standing around getting drunk and I wasn't thinking about it.....FAIL!
will be adding another yellow top before I put everything back in this time.
Edited by 07merc
yeah man thats bad news!... you ran the voltage right down... fry time!.... i have mine set up to where the car must be running to listen to audio...
whats under that false floor!?
