Posted October 13, 200818 yr I am in pretty desperate need of help...I tried to design a box and I keep getting lost. I am working with about 18" in height, 48" in width, and roughly 20-25" of depth. I would like to do 2 15" BLs tuned to around 34 Hz or so. Can someone please help me out. Thanks.
October 13, 200818 yr Check this out man. This should be perfect... besides the tuning. It is a bit low for what you wanted, but you can just make the ports a lil bit shorter. I already got cuts measured for ya and everything.http://www.rockfordfosgate.com/forum/topic...?TOPIC_ID=31174It was designed for two RF T1 15's, but it should work perfect for the BL's as well.... Edited October 13, 200818 yr by nick_19
October 13, 200818 yr Author ports shorter, do you mean ports 1 &2 or ports 3&4...sorry, like i said, new to this. I am assuming 1&2.Plus, if it is at all possible, I wanna make it 4" wider total and take that difference off of the depth. Edited October 13, 200818 yr by Xibalba
October 13, 200818 yr No. It'll be 3&4. Lemme do some math and stuff for ya and I'll get back w/ a new design for you tonight sometime k?
October 14, 200818 yr I recently built a box almost identical to what you are looking for. . .Here is the modified version to fit your dimensions:Brian
