And the problem is? We need more info. But, if the motor is damaged, might be wise to let it go.
it wont line up? You didnt drop it? you were driving when it happened? were you in an accident? lol j/k Sounds like you need to have the pros look at it? Did the coil come unraveled?
When you push on the cone is there a scraping noise? Or is there no movement at all? Check your tinsels too.
it wouldnt move at all. everything else was fine. the motor just wont line up right.
Edited by ElusiveJustin
If it wont move at all then it is seized up!!!!
doesnt this usually happen when the sub has been bottomed out alot?
More like it being overdriven for a long preiod of time....overheating and/or unraveling the voice coil at the same time.....then it will lock up....
  • 1 month later...
That picture shows us nothing since you took it at an angle.
when you click the picture, it comes up larger and you can see it then. and can i ask how in the world did you do that to that sub? lol
That was definitely dropped.
id say dropped or some freak defect..every1 makes mistakes
  • 3 weeks later...
Send that thing back in ASAP!
Fi Car Audio
Attn: Warranty Dept
5480 Cameron St #108
Las Vegas NV 89118
Please be sure to include a sheet of paper with your name, address, email, and phone on it as well as what coil was in it (D1 D2). We will get it taken care of ASAP.
Thanks,
Scott
  • 1 month later...
material failure ?? and u pulled the coil out .. just fine ? hm....
when it was still in my car i would push the sub in some and it wouldnt come back out, if thats what you mean.
