October 19, 200818 yr And the problem is? We need more info. But, if the motor is damaged, might be wise to let it go.
October 22, 200818 yr Must have gotten dropped, we've never had one of those break before...Is the slug cracked?
October 30, 200818 yr Author i dont see any cracks.i never dropped it. i was driving when it happened.
October 30, 200818 yr it wont line up? You didnt drop it? you were driving when it happened? were you in an accident? lol j/k Sounds like you need to have the pros look at it? Did the coil come unraveled?
October 30, 200818 yr When you push on the cone is there a scraping noise? Or is there no movement at all? Check your tinsels too.
October 31, 200818 yr Author it wouldnt move at all. everything else was fine. the motor just wont line up right. Edited October 31, 200818 yr by ElusiveJustin
November 3, 200818 yr More like it being overdriven for a long preiod of time....overheating and/or unraveling the voice coil at the same time.....then it will lock up....
November 6, 200817 yr Sounds like you clipped the amp and burned the coil up and locked it up.We've NEVER had a motor fall apart...the glue that we use to put them together is stupid strong.
December 15, 200817 yr That picture shows us nothing since you took it at an angle.when you click the picture, it comes up larger and you can see it then. and can i ask how in the world did you do that to that sub? lol
January 7, 200917 yr Send that thing back in ASAP!Fi Car AudioAttn: Warranty Dept5480 Cameron St #108Las Vegas NV 89118Please be sure to include a sheet of paper with your name, address, email, and phone on it as well as what coil was in it (D1 D2). We will get it taken care of ASAP.Thanks,Scott
March 2, 200917 yr Author when it was still in my car i would push the sub in some and it wouldnt come back out, if thats what you mean.
