I have always wanted to see a goalie accidently pass the puck to the other team from behind the net, it happened today.. :suicide-santa:
  • Replies 317.8k
  • Views 13.5m
  • j-roadtatts
    j-roadtatts
it's not like there is a secret to it...
Oh there are secrets ;)
let me in man :lol2:
You must discover them yourself young one :mexsmoke:
don't worry master, i will discover the path and set forth for it ^_^
oil change=90 bucks for my brothers BMW, Sean how much does your M5 cost?
Good god did they pour liquid gold in there?!
pretty much....ended up using around seven bottles of motor oil
That seems cheap for a dealerhip or shop.
$4 for the filter and ~$30 for synthetic oil
you do it yourself :drink40:
~10 for the filter and ~55 for oil for the E55
Guys...I'm working on the port size for an enclosure, I'm using these formulas : Sd = pi*(Dia/100)^2/4
Vd = Sd*Xmax/1000
Dmin = 100*(20.3*(Vd^2/Fb)^0.25)/Np^.5
And I came up with 264.9 in. That doesn't seem right at all
Math kickin' my ass top
Vd = Sd*Xmax/1000
dv = min vent dia in inches
fb = tuning freq
vd = cone displacement in cubic meters
dv >= 39.37*(411.25*Vd / sqrt Fb) ^(1/2)
Or
dv >= 39.37* (fb*Vd) ^(1/2)
Vd = Sd*Xmax/1000
fb = tuning freq
Or
So was I using the wrong formula?
Vd = Sd*Xmax/1000
fb = tuning freq
Or
I guess, where did you get it from?
The Subwoofer DIY Page - Port Calculations
huh, the ones I wrote are from the Loudspeaker Design Cookbook.
Thanks bromo I'll try those formulas.
Hey I tried to play with Excel and make it calculate using those formulas but I couldn't get it to work at all, any tips?
Well bromo I got 559.2 in with your formula, I'll do back and redo the Sd and Vd.
Make sure you write them right in Excel and have an example for checking.
I wrote them right, but it would be easier to see it done, I don't have any examples.
Okay I redid my Sd and Vd and came up with 52.7 in, that sounds much better :) Thanks bromo!
bromo with your formula is that for a round port or slot port? If it was for a round the conversion to a slot is Dv' = 2*((W*H)/pi)^0.5 right?
Damn...it's a lonely night!
