  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
sean which specific calls are you talking about?
calls?
from the saints and vikes game
calls?
pass interference, complete catch and the 1st down spot all completely jacked in one possession in overtime :(
calls?
Agreed, the pass interference for sure!
Stop talking about it. Just bad memories
calls?
pass interference was a bad call but still all the turnovers lost them the game, cant argue the turnovers
Except they were in it until the refs took it away.
No way was he kicking from >50 yards and that last catch was NOT a catch. The refs gave it to them.
The setup for that play had crap calls too, the Vikes should have had the ball and the Saints couldn't stop them without the VIkes giving them the ball. The outcome would have been different.
calls?
x2, that is what made them go into overtime in the first place. If they would of eliminated those turnovers then the Vikings would of won the game within the 4 quarters because their performance showed it.
6 fumbles and 2 INT? Is that bad?
one of the INT should of came back, because they broke favre's ankles on that play
After I just installed some new speaker wire in the car I was thinking of speaker wire for subwoofers and the size being used nowadays such as 8 gauge. If Im correct voice coils dont like heat or too much heat, thicker wire passes more current which brings on heat. So would it benefit you to go bigger on speaker wire for your subwoofer and if not what should be the biggest and safest size to use?
Wire doesn't PASS current, it handles it. Just because you have larger wire, doen't mean your current in that cable will increase. It simply means it has the capability to handle more current.
Ok makes sense now, thanks for that bit of info.
