  • Replies 317.8k
  • Views 12.8m
  • j-roadtatts
    j-roadtatts
The house is quiet once again. Kid free currently.
Curious if I can manage to get some more valvetrain business now that fi is in the mix. It should make the heads at least as important
You should. I don't know if they are going direct or port, but with the injection, air velocities will change, so you get the ports, chamber, valves, and cam.
Well got the car yesterday. Today took it back cus as soon as I hit 60 car shakes violently. Under 60 it drives perfectly fine. FML
6AM, I should probably get some sleep.
Blow the fuckin thing up man, or have it stolen.
Jq
Wheel balance ? Everything tightened correctly ? Did you check all the adjustments ?
They did all that when they put the car back together. The axles were replaced. Pretty much the whole suspension was replaced. But for some reason a soon as you hit 60 it just shakes. So they'll try to figure out what's wrong.
May be getting one of these, need opinions from you bikers on here
http://www.gpsportsonline.com/m_vehicledetail.asp?veh=206665
No. NEVER buy new
I agree with Sean. If you are looking at that 250 you can get killer deals on used ones.
