The ML is starting to become mundane and boring. :Doh:
Got a replacement in mind?
Have 2 more years on the lease...BUT I think I am going to start test driving :)
You need to start now for sure. you may have decided by the time you retire.
Exactly, time to test drive :)
  • Replies 317.8k
  • Views 12.7m
  • j-roadtatts
    j-roadtatts
010000110110110001100101011000010111001001101100011110010010000000110100
0100100101110100001000000110100101110011001000000110110101101111011100110111010000100000011001000110010101100110011010010110111001101001011101000110010101101100011110010010000000111000001000000110011101101111011011110110010000100000011100110110100101110010
01001001001000000110110001101111011100110111010000100000011101000111001001100001011000110110101100101100001000000111011101101000011000010111010001110011001000000110011001101111011100100010000001100100011010010110111001101110011001010111001000111111
01110011011011110111100101101100011001010110111001110100001000000110011101110010011001010110010101101110
011010010111001100100000011100000110010101101111011100000110110001100101
Where did you find white velocity amps? Mine were black and I've never seen white ones. I thought you were running the design refs?
Different model years. The black Velocity amps were the older models, the white are newer models. They were getting blown out a couple years ago so they were really good deals for the power and quality.
I haven't had the DR's for several years. Sold off the majority of my collection.
I wanted to buy 2 DR amps from you when I first got into the game :D
Finally able to do the gym after work tonight.
I expect this evening to be hell.
J
Have I read wrong or it's true that it's better to leave the vehicle working if you know you'll have to start it again after ~5 minutes?
Something about the engine and fuel consumption when you fire it up.
:ughdunno:
I just watched like 47 toe touches.
:ughdunno:
i heard the same thing, something like ignition burns more gas than five mins of idle, but idk the truth.
:ughdunno:
Not really true. However it could cause more wear and tear... but still not likely on the engine, but yes the starter.
Verlander for MVP. With no position players standing out this year and ESPN giving him a big push, he is going to win it.
Never happen. By your logic, Mariano Rivera should be MVP ever year. Plenty of position players excelling this year, and the Tigers are in a WEAK division. Put him in the East and his wins are halved.
:ughdunno:
It may hold true on a carburetor, and an old one, but nothing built in the last 20-30 years.
I'm confused, what does the starter and carb have to do with each other. I must be missing something, as using the starter more would cause more wear wouldn't it?
I was just adding to your post, sorry. To alleviate the confusion, the carb could cause the engine to use more fuel on start up versus more modern engines.
You were spot on on the wear issue, but even that will be negligible.
Thank god. I thought I lost my mind. I'm still at work.
THoguht maybe the office evil radiation was melting my brain.
it would be a stretch but a warm start-up may be worse on the starter(solenoid), because of the ambient heat. That's one of those things that can sound good on paper and never work in real-life though. Definitely wouldn't cause me to not shut my car off for 5min.
I'm glad I didn't go with 8s Sean, I started making the baffle for both the anarchy and hds as one, like this:
Man is it big! May have to cut it into separate baffles and play around with positioning.
I should have everything by the end of the week - beginning of next week.
I'm stoked.
How can you drive? Your pedals are on the wrong side!
I just found that pic on the interwebz, not my car. :P
