  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
Run, run, run, run, the revolution has begun
Run, run, run, run, run into the rising sun
a ratatat tat and a rumpa pum pum
Is the sound of the gat and the sound of a drum
and whatever you attach to is what you become
I thought you were only bench shooting? Can't imagine a tactical somewhat heavy stock humped around for hours hunting.
Well the sako isn't that heavy. A 20 pound gun for me isn't so heavy to walk with.
As for hunting, there is much less running around than most thing. In the woods you find a stand and..... wait. In the plains you spend your time looking and moving slowly.
20 pounds is fuckin heavy.
My old 22.250 varminter weighed in at ~9.5 pounds, and that was heavy.
Why not look at the Tikka Super Varmint series. It is available in 7MM Mag, .300WM and .338WM. Weighs in at 8.5 pounds
We were talking about heavy guns earlier... hell is humping a big shotgun. Double bbl makes it even worse. All the weight up front. FML.
Seriously, show my a double barrel that weighs 20 pounds.
My Model 37 is like 6.5 pounds. I'll carry that over a 20 pound match rifle any day.
Hopefully someone can help me out.
Packrats got into our jeep cherokee (2007 Mercedes diesel engine) a week ago, and ate up the fuel lines (on top of engine). Had the fuel lines and fuel filter replaced. Drove fine for twenty minutes then started cutting out. It was worst taking off from stoplights. Engine light code is P0087 (Fuel Rail/System Pressure - Too Low).
Could the damaged fuel lines burn up the fuel pump since it was driven for five minutes before the engine finally died? Could the injectors been damaged as well?
Edited by stefanhinote
I was not saying that 20 pounds was light, or that a shotgun i have every carried was 20 pounds either.
I was saying I don't mind carying a heavy gun when it sits well, and my worst experience was with this absurdly heavy BBL shotgun. It had every last ounce of it's weight at the tip of the BBL. What a fucking nightmare.
My AR-10 is pretty heavy for a rifle you would have to run around with, but because the weight is better ballanced, It didn't bother me.
Nope. If they got on top of the motor, I would be checking the rail line pressure sensor wires, or possible the sensor itself. If they got through the lines then some plastic may be stuck in the sensor.
Why the fuck is everyone glorifying Jovan Belcher? Fuck that guy, I hope he is burning in hell.
Makes no sense. All I know is if he didn't play football people would have a different attitude towards him.
Thanks.
The injectors no, but they could have chewed some wiring or pieces have been lodged in the lines somewhere.
20 lbs. of brisket and 8 lbs. of pork shoulder going in the Egg soon...ish
I did 4 racks of St Louie's today with about 3 lbs of Ribeye Bulgogi
You have my phone number. Wtf bro.
Manwhich and green beans here tonight.
J
wtf is manwhich?
Brand name of sloppy joe mix.
The 13 lb. brisket finished in 8 hours @ 250F. Damn.
Huh? Shouldn't hardly be in the plateau in 8 hours. 250 is hotter than I've ever smoked anything though
Lean as hell. I put on an 8 lb. brisket that finished in 7 hours @ 250F today.
I think I just birthed a manwich.
Edited by dem beats
