And once you got him talking about practice. He would soon forget about any trouble :)
  • Replies 317.8k
  • Views 14.5m
  • j-roadtatts
    j-roadtatts
I still some how managed to get isd an awful lot though :(
Didn't really understand how that was punishment though :)
ISD?
Took like an hour to do all your classwork for the day. Then you could sleep the rest of the day :)
its going to be the secret mattie metallic
i'm going ot mix it with a little bit of my blood...wait, i need to figure out if it will mix, i might just be able to add plasma or the platelets or something
Or is that pearlescent ? :)
Ramos, how much paint will i need for a fiero? any idea? i'm thinking 1 gallon won't be quite enough
Don't ask how I know this, but know it won't :D Blood is heavier than the paint and will seperate :)
With candies and transparent the more coats, the darker and richer the color. :)
You can compensate for some of the darker or lighter color with the base coat. :)
i'm going to need enough to do 3 coats so i suppose 2 gallons here i come
Are you seriously looking for a custom color, or is it something off the shelf. The reason I ask, is I have an account with a local paint store in the noke. Sometimes with a large enough purchase I can get some good deals through him :)
custom going one of two ways with it
F'in A that was a good nap. Loritabs knock me out.
:BURP:
Moutian Dew
Ok, heres an Idea for a case for my rack gear ( 6 rack spaces worth)
Its gonna be a 3/4" ply box, painted black using the leftover paint from when I had to repaint the fender on my S-10 (old woman hit me so I had some body work to do), hidden castors underneath for easy movement of the ~60lbs of total weight.
It will have a front cover that lifts up and slides back into the case. Everything, including the inside will be sprayed black (the front "door" will be frame with probably heavily smoked glass set in it). When you open the lid it will reveal a piece of 1/2" thick plexi recessed into the front above the rack gear with Behringer (possibly the symbol for it too) since 3 outa 4 of my pieces are behringer and I want to do something with plexi and led's.
It will have led's drilled into the sides (of the plexi, probably white led's) to provide illuminaton of it, with a dimmer switch recessed into the side of it to control it.
Is this stupid or could this have the possiblity to look somewhat cool?
for chits and giggles i googled LoriTabs... i had no idea they where an opeate.
